cummins2014
May 05, 2020Explorer
fj12ryder wrote:
Well, I've had the TST system for 6-7 years, and it only happened that one time. But it also reconnected on its own. How many times had it happened before and I never noticed it? How many times has it happened to you and you never noticed it? How many times have we been running down the road thinking it's working, and it's not? No way to tell with an hour wait for notification.
Just because yours has never alerted doesn't mean the monitor hasn't lost connection to a sensor. It just means that if it did, it reconnected within an hour so it never alerted. No way to tell.
As far as I know I haven't lost connection with a sensor. It gets looked at quite frequently, so if it did then as you say there would be a difference in the readings before things got heated up. So far that has not happened as the temperature ,and pressure increase. Now if it loses connection after everything has topped off, and running pretty consistent, well there is no way to know I guess on that part .
I trust the system,so hopefully that is not happening with a repeater . I can't help thinking that was your problem. Its apparent it was an issue losing connection on a sensor before they started coming out with the repeater .
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
