MartyW's avatar
MartyW
Which valve stems for tpms ?
Hi to all,
We're replacing our TT load range C tires with load range D tires. Many thanks to the folks who helped with that decision. The wheel manufacturer (Series06) recommends using a stronger valve stem when switching from the 50 psi to 65 psi tire.
With the new tires & valve stems we will want to use a tpms, and two questions come to mind concerning the tpms and valve stems:
With the tpms, are folks favoring the new flow-through sensors or are the lighter original non-flow-thru sensors still preferred? The flow-through sensors seem nice but is the added weight a concern for valve stem stress or balance?
And with the tpms sensors is a metal valve stem recommended?
So far our tpms research is pointing to probably either TST507 or TireTraker but not positive yet. The sensors appear to be pretty much the same in several of the new units with the same replaceable batteries.
Thanks in advance,
Marty
Looking for advice before your next adventure? Look no further.25,167 PostsLatest Activity: Oct 05, 2025
