fireman41
Jun 03, 2016Explorer
This is like asking what truck is the best.
Now I have only had 3 different hitches. A cheap round bar a pro serious and a Anderson no sway. Out of the 3 I like the Anderson the best, now it by no means perfect, but it is close.
The pros about the Anderson is that it is real easy to set up. Just set the ball height and attached the brackets and adjust the change the move the amount of weight you need moved.
The cons.
People have reported that with real heavy trailers they can't get them to move enough weight
Not compatible with some trailer hitches
Also you should carry and extra nylon spring bushing, cause if you break one the sway control and weight distributing part of the hitch can't be used.
It's not perfect but I like it. I towed my jayco 26bh with my F250 out of of the Outer Banks last year a day of two before the hurricane came ashore and it was Rock Solid.
The cons.
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
