bsmith95610's avatar
bsmith95610
Which weight distribution setup do you recommend?
Hello,
I just purchased a travel trailer and am now looking to get a weight distribution hitch. My trailer is 23 ft long and weighs about 5000 lbs loaded. I don't want to buy a cheap weight distribution hitch but I definitely don't have the funds to get an expensive one either. I am hoping to get something that comes with sway control but if not then I'll add it later on. Below are the hitches I've been looking at in order of what I'm thinking about buying with the most likely on top so please let me know if you have any feedback on any of them. I picked out three on the cheaper side and three in the mid-range side. Any help would be much appreciated.
Pro Series Weight Distribution System w/ Friction Sway Control - Round - 10,000 lbs GTW, 750 lbs TW - $256
https://www.etrailer.com/Weight-Distribution/Pro-Series/PS49902.html
Curt Weight Distribution System with Shank - Pin-Style Trunnion Bar - 8000 lbs GTW, 800 lbs TW - $255
http://www.etrailer.com/Weight-Distribution/Curt/C17341.html
Eaz-Lift 48057 Elite Weight Distributing Hitch Kit - 800 lbs Capacity - $241
http://www.amazon.com/Eaz-Lift-48058-Elite-Weight-Distributing/dp/B005SB6S3Y/ref=sr_1_1?s=automotive&ie=UTF8&qid=1464973279&sr=1-1&keywords=Weight+Distributing+Hitch
Curt TruTrack Weight Distribution System w/ Sway Control - Trunnion - 10,000 lbs GTW, 1,000 lbs TW - $379
https://www.etrailer.com/Weight-Distribution/Curt/C17500.html
Husky Center Line Weight Distribution w/ Sway Control - Trunnion - 12,000 lbs GTW, 1,200 lbs TW - $400
http://www.etrailer.com/Weight-Distribution/Husky/HT32218.html?feed=npn&gclid=Cj0KEQjw1cS6BRDvhtKL89em1oIBEiQAtZO5x9g5xZMpJWPI9FkZ7_HeacRZgClGVGH9pGrt4x0vBZUaAm5y8P8HAQ
Strait-Line Weight Distribution with Sway Control - Trunnion Bar - 10,000 lbs GTW, 800 lbs TW - $480
http://www.etrailer.com/Weight-Distribution/Reese/RP66073.html?feed=npn&gclid=Cj0KEQjw1cS6BRDvhtKL89em1oIBEiQAtZO5xwocJbkZNm-nuz_73emfNEbEBwtYDuTlBTh9XCKDHxkaAjWz8P8HAQ
Thanks
  • OK...here's another one not on your list. I've pulled various trailers for 50 years and by far the easiest most effective one I've found I now use and that's the Andersen. I've heard that they are not so good on really large trailers, but don't know that for a fact. I do know on my setup there is absolutely no blow by or suction from large semis passing me and it is very easy to hook up.
  • Skip the friction sway bars and go for ones with built in sway control. Top 3, in no order, seem to be Equil-I-zer, Reese dual cam, and Blue Ox. Might be a few more bucks but pennies considering the investment you are protecting. Worth every penny.
  • I had a blue Ox Sway Pro and was a white knuckle drive. Change to the more expensive Reese Straight Line Dual Cam system and it turned into an easy 2 hand drive. Went to bigger truck and bigger trailer, now a one handed piece of cake. Still it's better to keep both hands on the wheel. Reese hitch is noisy turning a corner, but really works great on the highway. If you have the right setup like I do now, you won't even notice the 18 wheelers unless you see them coming.
  • neither is my 4 point Equal-i-zer w/built-in sway control, in the OP's list.
    only cost around $450 with free shipping from RVW.
    i have a similar weight trailer and i would never purchase a WDH without built-in sway control
  • I love my Blue Ox Swaypro, but it's not on your list. Prior to my Blue Ox, I used a Husky Centerline TS which, I believe, is the same as the Husky on your list. It has sway control. It worked out really well for me too. Only reason I replaced it, is my new trailer tongue weight exceeded 1200 lbs and Husky max is 1200.
    If there's one recommendation I would have for you, is don't cheap out on your WD hitch selection. It's one of the most critical safety items you have. The Blue Ox Swaypro is a tad pricier, at about $600, but worth it in my opinion.
    Mike
  • From your selection, I would choose:
    Because it has the built in sway control, the others do not.
    This Reese does have sway control but it's higher priced.
    http://www.etrailer.com/Weight-Distribution/Reese/RP66153.html
    Personally, I have the Equal-i-zer. It's the closest to the Curt Trunnion you listed above.
    I had a Reese, with the chains, and will not go back to another system using the chains.
    Click here. MY choice and the one I use.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
