Ron_Gratz
Jul 18, 2013Explorer
kamperdog wrote:I assume the 219# is the brochure dry weight. Do you know what the loaded tongue weight is? And, do you know what the trailer's loaded total weight is? Without those numbers, we don't have much basis for speculating on why you're having sway problems.
---My base tongue weight is 219---
---But I still get what I think is too much sway with it even though I have a WD hitch and the 4-point sway control setup.How do you have the WDH adjusted?
So I'm looking at the tire pressures on my trailer. How would you set your pressures on a tandem axle setup?I would set the pressure to the maximum stated on the tires.
Ron
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
