Francesca_Knowl
Jul 18, 2013Explorer
Ron Gratz wrote:Francesca Knowles wrote:Probably not true in this case.
First thing I'd look at is coupler height- that should be dead level when hitched, or very slightly low. If it's high, you effectively lighten the tongue. Lowering it a bit below level has the opposite effect and might be worth trying if you can't beef things up by any other method.
I believe that trailer has the Al-Ko independent torsion axles.
If so, if it's high, you effectively increase the tongue weight. Lowering it a bit below level has the opposite effect.
Ron
OOPS!
For some reason I thought it was a single- thanks for the correction.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
