BenK
Aug 26, 2015Explorer
Both push and pull...
The front of the 'other' vehicle has a high pressure area in front
of it, as it is moving/pushing ahead. It will be in the form of
a 'V', or a wake of a boat going through the water
Behind that 'other' vehicle will be a vacuum pressure area in back
of it, as it is moving ahead and the air will be backfilling the
void. Vortex at all of it's trailing edges.
The faster the 'other' vehicle is going, will have both these
effects become ever greater
Now your vehicle is also doing the exact same thing...
As the high pressure wave touches your vehicle front *AND* then
ride down the side of your vehicle(s)...it will push on the side
and your vehicle will try to pivot on an axis...the tire in this
case
As the high pressure wave continues down the side of your vehicle,
it will continue to push and try to push your vehicle on a 'pivot'
This is why 'P' or soft side walled tires will allow the vehicle
to 'wiggle' more than a higher strength sidewall. In the case of a
dually, 8 side walls and a much wider stance (track)
Then it gets to the trailer's front area.
Now there is a *new* pivot point and is the connection or ball
Both Fiver and tongued, but the Fiver's pivot point is on top of
the TV's rear axle. So the moment (engine speak for lever arm)
is very small to nothing if dead centered on the rear axle center
line
This is why folks recommend or talk about the over hang of the rear
from the rear axle to the ball...much longer moment
The trailer also has a moment from the ball/coupler to it's tires
center line (if dual axle, centered between'm, etc)
This will have the trailer potentially sway if there are no anti-sway
measures
Then the 'other' vehicles rear end vacuum comes along to do the
exact same thing, but opposite...vacuum...so pulls on the side
of your setup
Ditto a building you pass at high speed...just that it will be
a 'wall' that your high pressure bow wave and low pressure wave
will have that high pressure against that building wall and your
vehicle side...
case
line
measures
of your setup
vehicle side...
JD and Beastlet wrote:
Nope, it's not the first line of a joke or a rhetorical question.
I would expect a passing truck or bus to be pushing a wave of high pressure air in front and beside, but I've noticed time and again that passing trucks and buses tend to pull our trailer in towards them rather than push it out. It's a point of curiosity for me and I'm interested in the explanation.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
