WyoTraveler
Aug 08, 2015Explorer
If you have A/C heat pumps they will heat and blow air through the ceiling ducts. Newer RVs the heat pumps are interconnected with the furnace. When it is too cold for the heat pumps to maintain the set temp the furnace will come on. At times mine cycles back and forth between the A/C heat pumps and furnace. Not sure which system you have. Posting a picture of your thermostat would be helpful.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 13, 2025
