- sgip2000ExplorerThe reason for this is to keeps the trans lubed.
- traveylinExplorerI get 600 miles on a tank of gas and travel usually 200 miles per day. What is the logic in running the toad at a gas station every third day
- DutchmenSportExplorerYou must have an Chevy Equinox as your Toad. If so, yes, run the engine as recommended.
- K_CharlesExplorerMy manual says I don't need to do that so I don't. If it said to, I would.
- LwiddisExplorer II"the smartest choice is to do exactly what the owner's manual says to do"
Absolutely, right. Why jeopardize your vehicle's warranty? - bgumExplorerBecause it will make your toad last longer with fewer repairs. It provides some lube to vital areas.
- DownTheAvenueExplorer
TheLuvShack wrote:
Why run the toad engine at every fuel stop?
Is this recommended to keep the battery charged or lube the transmission or both. My toad battery charges through the umbilical cord. Will I damage the transmission by not running the toad engine for the recommended five minutes?
Do what you want, or do what someone tells you here to do, but the smartest choice is to do exactly what the owner's manual says to do. - wildtoadExplorer IIthe main purpose it to lube things. Just like you should run the engine before you take off in the morning, you should run the engine as per the vehicles towing documentation. It's not worth the risk of not following the instructions.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
