jerem0621's avatar
jerem0621
Explorer II
Aug 30, 2018
Why Would Anyone Choose Above Bed Fifth Wheel Rails?
Here are some of the reasons I can think of buying above bed ISR fifth wheel rails as opposed to an under bed set of rails.
1) Cost and ease of installation (with frame specific install kits)
2) Compatability with a large spectrum of fifth wheel hitches from all manufacturers without the need for special and expensive adapters
3) extra tie off points when hauling a load in the bed
4) easy to convert to a gooseneck hitch by installing a relatively cheap gooseneck plate adapter in the rails
That’s about all I got. Anyone else have any reasons to install above bed rails as opposed to an under bed solution?
I know one of the cons include not having a flat bed when not towing.
Thanks
Jeremiah
  • jerem0621 wrote:
    bluie5 wrote:
    I put rails in my truck because I think it is a more secure way to use my Andersen hitch.
    I agree with you on that. The Rail Version of the AUH is the most robust design IMHO.
    Thanks!
    Jeremiah
    I also agree !!!
    Thanks!
    Jeremiah
  • I put rails in my truck because I think it is a more secure way to use my Andersen hitch.
  • IdaD wrote:
    Those are basically the reasons I went with ISRs. Cost less, easy install and it offered lots of flexibility for rail mount hitches and the drop in gooseneck plates. It hasn't bothered me having them in there and they make handy tie down points for cargo.
    I can't agree with mowermech on taking them in and out. Some of the bolts on my installation aren't easy to get to at all and they're torqued spec which was pretty **** tight.
    The Husky Hitch I had was in my old 1994 Dodge Ram 3500 CTD LWB.
    The frame brackets were installed in places where getting at the rail bolts was not a problem, if I wanted to remove the rails. I torqued those 5/8 inch bolts at the initial installation, and forever after it was "tight plus a grunt" with a 2 foot cheater bar. They never came loose or broke.
  • I have been using the in bed rails for close to 25 years now. Started with a gooseneck hitch and later added the fifth wheel hitch. I’ve swapped the rails now between 3 different trucks. Just bought new bolts. On the rare occasion that I need a flat surface, I have a sheet of one inch plywood with cutouts. Works fine for me.
  • Thank you for the feedback everyone. I like the ISR solutions for fivers and goosenecks.
    Thanks!
    Jeremiah
  • Those are basically the reasons I went with ISRs. Cost less, easy install and it offered lots of flexibility for rail mount hitches and the drop in gooseneck plates. It hasn't bothered me having them in there and they make handy tie down points for cargo.
    Thanks
    Jeremiah
    Pretty hard to argue with logic and facts....though many do!
    A couple of sections of 3/4” plywood, cut to fit....pretty much eliminates the rails in the bed argument! Though....those with a short box truck, will complain about the loss of storage room! ;)
  • Yep, all those reasons, except for the gooseneck ball. It was installed in my truck when I bought it.
    As for having a flat bed when not towing, it took me just a few minutes to remove the four bolts holding the rails when I didn't want them in the way. No problem at all.
    The main reason I went with that particular Husky hitch was that is was on sale at the time, for a considerable saving. Saving money was a great deal more important than any consideration about the in bed rails.
    I made a spacer out of 2 inch lumber so that I didn't have to remove the rails when hauling my 11.5 foot slide in camper.
