- hotpepperkidExplorerLegal in CA but you need a commercial with double endorsement
In AZ needs to be 5th wheel and no special lic - samsontdogExplorer
Cummins12V98 wrote:
1320Fastback wrote:
See it all the time in California, well ones properly set up.
A vehicle towing TWO ball type trailers?
I did it for 16 years. Two ball type trailers which are legal in Calif - drsteveExplorer
mkirsch wrote:
Over and over you've said, "if done right..."
How many know how to do it right?
Yeah we all know that a smart responsible adult would do their homework, but not everyone (I'd dare say most) are not as smart and/or responsible as they should be.
I suspect this is the reason many states ban this kind of setup. Too easy to do it wrong. - larry_barnhartExplorerI guess I am the only one to notice when following a MH with car trailer or a TT behind any truck that goes left and right at every wiggle from the tow vehicle. Add another trailer and it just gets worse .
chevman - Cummins12V98Explorer III
noteven wrote:
Yes. And 3 flat towed Jeeps ..
Personally never seen anything like that in CA. - notevenExplorer III
Yes. And 3 flat towed Jeeps .. - notevenExplorer III
firemedic1992 wrote:
SDcampowneroperator wrote:
Legal in many States and Provinces. Like any double tow correct hitch weight and set up make it possible, safe. Increaed tongue weigh on the first trailer to compensate for the rearward shift of weight caused by the tongue weight of the second trailer. Brakes and sway control bars on both trailers.
That guy did it all wrong.
No provinces in Canada allow double towing with a travel trailer and only a few allow it and the lead trailer must be a fifth wheel.
Did SK change their regulation? Usta be lead trailer must be tandem with brakes on both axles #2 has to be less weight than lead trailer. - mkirschNomad IIOver and over you've said, "if done right..."
Yeah we all know that a smart responsible adult would do their homework, but not everyone (I'd dare say most) are not as smart and/or responsible as they should be. - dodge_guyExplorer IIThose are also the same guys that think they don’t need a WD hitch because they have a big truck!
- dodge_guyExplorer IIMust be the dumber friend of this guy!
Moderator edit to re-size pictures to forum recommended limit of 640px maximum width.
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Mar 04, 2025
