tvfrfireman
Jun 17, 2013Explorer
Will adjusting B&W pivot arms forward help ride?
I have a B&W with a Companion Fifth Wheel hitch and am trying to improve the ride. Our fiver has about 3800 pounds of pin weight and the trailer is just over 17K. When we hit those bridge and overpass transitions in the pavement, the bounce gets pretty violent on some. I have installed air bags which helped a little and some stable lift spacers that engage the overloads that did the most good. It is still a rough ride and was told by someone on another form that I should move the pivot arms two inches to the forward adjustment which will put the king pin about four inches in front of the rear axel. I wrote B & W and they said they had no idea if it would help but said to give it a whirl. Do any of you have any experience with this? Thanks in advance.
