nomad_297's avatar
nomad_297
Windjammer Rain Forest — HELP, Please!
I have never experienced this before in the few years I have owned my windjammer, or any other travel trailer for that matter.
For the last five days, we have been camping with relentless rain, The outside temperature has been fairly consistent at around 68 degrees to 73 degrees, day and night, and the outside humidity has remained at 97% humidity or higher for the entire time — my hygrometer for outside will only register a maximum of 97% and that is where it has stayed for the entire five days. To keep the humidity inside of my camper to less than 60%, I have had to run the A/C, so I keep it at about 68 degrees so it will run to bring the humidity level down. This is cooler than I like, but it is the only thing I can do to bring down the humidity to a livable level. If I use my MaxAir fan, the humidity inside shoots up, so I have quit using that unless we are showering or using the bathroom.
What I am seeing is condensation collecting and dripping from all of the A/C registers, around and on the A/C unit and on the ceiling where the ducts are carved through the styrofoam — the closer to the A/C unit the ducts are, the more I see the condensation.
What makes this happen and what can I do to combat it? I don’t think a dehumidifier is the answer because they generate so much heat, it will make the inside of the camper uncomfortably warm.
I am afraid if I let this go on much longer, I will be dealing with mold or mildew in the near future.
Any suggestions or solutions will be greatly appreciated.
Thank you,
Bruce
Looking for advice before your next adventure? Look no further.25,174 PostsLatest Activity: Oct 26, 2025
