doxiemom11
Jul 27, 2018Explorer II
Run you furnace. The forced air blowing out of vents will reduce the humidity just like it does in homes in the wintertime. We have also used the furnace, heated it up to 78 or so, then switch to air and took the temp back down to 72. That will dramatically reduce the humidity. After a couple hours, do it again. A dehumidifier will also help.
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 19, 2025
