Blazing_Zippers's avatar
Blazing_Zippers
Explorer II
Oct 22, 2014
Winter battery care
We have two Costco 6 volt batteries that are almost 4 years old on our trailer. In our neck of the woods, winter might spike down to -10 degrees or so, but mostly hovers around 10 to 30 degrees for the low temps.
SO, my question is this; With the rig being plugged into 30 amps, would you consider it best to leave the batteries on the rig, OR unplug the 30 amp circuit and remove the batteries (placing them in a warm area)during the cold times?
I see farm equipment etc. with batteries left in the cold with no winter precautions, and there "seems" to be no problem with them. Also, after a few years, most RV batteries lose most of their capacity, so is the extra time and effort worth it?
Thanks
  • It really depends on what converter/charger you have as to whether you should leave them in the RV.. If it's a 3 stage unit then you will be fine. If it's a single stage (13.6V constant) then it will eventually boil them dry.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
