Travlingman's avatar
Travlingman
Explorer II
Nov 26, 2013
Winterize washer
Our new rig has a Whirpool washer in it, separate from the dryer. What steps do you follow to winterize it? I normally use air to winterize with pink stuff in drains, but have never had a washer in rig before. Does anyone use air or do you winterize with pink stuff on your washer?
  • You need to get pink stuff into the p trap. I have a Splendide. The manual says 1/2 gal of pink stuff in the washer and spin it out down the drain. That gets it both into p trap and pump. i shut off washer water valves and the hoses will drain. I blow every thing out with air. Making sure those valves get blown out I connect a short piece of hose from each washer fauset into a pan when I blow those lines out. Just a little extra work with a washer.
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 19, 2025
