john_bet
Nov 18, 2014Explorer II
nomad 289 wrote:I must be one very lucky dude. I have never used an additive in my truck. I even drove it to Great Falls,MT. at Christmas time of '12. I have no cord for the block heater either. Several nights in Great Falls it fell to -4 and truck started right up. Never had a gelling issue going out I-70 then north or coming back via I-90 and I-80. All the way across Iowa it was 0 degrees. Truck performed as expected and it is a 2wd if that makes any difference to you 4x4 fans that insist that all tv trucks need to 4x4. JME.ShotinAz wrote:
At what temperature does diesel gel?
17.5 F
Problem is, the wax crystals that form and clog your fuel filter then have to be heated up to around 32F to unmelt and remix.
Don't think all Engine block heaters heat the filter/fuel pump, so I use an additive when Daytime temps of below 32 are forecast.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 11, 2026
