usaclark's avatar
usaclark
Winterized RV/Electric Heater?
No question is to dumb, right? My new travel trailer will sit outside all winter but I do have electricity to it. I will winterize it. Do any of you place some electrical heat source in your RV during the winter months that is safe or is this is just a crazy idea and not even necessary? If you do use some kind of electrical heat, what device do you use?
  • Years ago, I tried using the TT in winter as an "addition" on the house. I covered the area under the TT with bubble-wrap concrete blanket (used by builders to keep concrete warm during winter curing)skirting. Then I built a short "air-lock" to attach the entrance to our enclosed deck. Then I ran an electric heater inside. As soon as the temperature dropped below about 45 degrees the electric heater ran continually and when it got colder outside it required the propane furnace to come on every so often. This was just an attempt to keep the inside of the TT at 60 degrees. I gave up after one winter because it was too expensive.
    An electric heater (1500 watt) running for 24 hours (at an electricity cost of 15 cents per killowat-hour) will cost $5.40 per day to run. This is a lot of money.
    Steve
  • I prefer not to let the inside of the RV get below freezing, as frozen condensation can do a fair amount of damage. In our soggy winter climate, condensation is a permanent issue.
    I use one of those oil-filled radiators and a plug-in digital thermostat. The t/stat bottoms out at 45 degrees, which is higher than I really wanted, but I put it in the vicinity of the heater. I have an indoor/outdoor thermometer and I put the "outdoor" transmitter on the doghouse of the RV and take the display into the house. It has max/min readings, so I can keep tabs on how cold it gets inside the RV.
    I run the power cord through a Kill-a-watt meter to see how many KWh the heater uses and in last year's fairly mild winter the total used in 4 months added up to around $35.
  • We keep a " milk House " heater turned on in our TT on the few nites it gets colder than 25 degrees . We never winterize as we use our TT many times all winter .
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 17, 2025
