George_H's avatar
George_H
Winterizeing air pressure
Saw a recommendation to use 80 lbs. air pressure to blow out water lines. My 05 5er has PEC water lines and factory warns against any water pressure over 45 lbs. I would assume that applies to air pressure as well. Maybe OK with all outlets open?
  • 80 psi is too high...and unnecessary.
    Go with about 45psi. It will do the job very nicely.
    I have been using 45psi for well over 20 years.
    Where? I've never seen anything that high.
  • 1/2" PEX is what is used for plumbing lines
    Not sure where/why 'factory' would warn of not using pressures over 45#?
    Standard water pump has a 45# discharge pressure.....upgrades/optional water pumps have 55# discharge.
    Water pressure regulators come pre-set at 45-50#
    And if PEX got really hot it still is rated higher
    PEX
    Pressure/temperature rating 160 psi at 73°F
    Pressure/temperature rating 100 psi at 180°F
    Pressure/temperature rating 80 psi at 200°F
    40# air pressure is sufficient to blow water out of lines
  • Yes, stay with air pressure that's close to your working water pressure or slightly less.
    Bill
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 15, 2025
