Johno02
Nov 19, 2016Explorer
Winterizing tip.
Just a quick tip for a few new folks out there to help with winterizing. When you are draining your water heater, after removing the drain plug, or opening drains, raise the lever on the safety valve on the water heater tank. This lets air into the tank much quicker, and lets the water drain out a lot faster. After it all drains, be sure to return the valve to its closed or normal position.
