CarnationSailor
Dec 05, 2016Nomad
westend wrote:
If you can drain all the water and then can blow the lines with air to remove any residual water in low slung areas, you can put your WH drain plug back in and set the valves for normal use.
I would say leave the valves set for normal use because there is no need to do anything with the bypass valves if you are just going to blow out the system.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
