dwayneb236
Jul 04, 2016Explorer
myredracer wrote:
Just got a Garmin 760LMT along with a BC-20 backup camera. DW seems to think I need a backup camera although she never drives the truck or backs up the TT. I think it's going to be a waste of time and money.
I don't know about other backup cameras, but the wireless transmitter is too far away and you need to buy their 30' long extension cable to mount the transmitter in the front of the trailer somewhere. I don't like the fact that there is no way or place to mount the camera without drilling into the exterior fiberglass wall. Then you need to run the cable somehow from the back to the front which I can do, but it's many hours of work. The cable and connectors are not outdoor/weatherproof rated. Then you have to get 12 volts to the wireless transmitter. Not sure if that should be via the TV's backup light power?
And if you manage to get the camera and wiring all installed, I have read of many reports of the image being washed out in the daylight and you can't see much, if anything. I am going to a temporary test setup before installing anything. Maybe some other brands of camera images are better than others? Not sure if dirt will accumulate on the lens also obscuring the image and if it needs periodic cleaning, you'll need a stepladder to get to it.
I've got the same unit. Here's what I did. I wired a power port to my back up lights under the rear of the truck, which powers the camera when I go in reverse obviously. I also wired a separate power wire coming from one of my upfitter switches. This is when my trailer is attached. I just unplug from the back up lights and plug in to the upfitter power. This way I can turn to camera on when I want. I have an extension running to the rear of my trailer. I just unplug the camera from the bumper plug where it's clipped to the license plate and plug it in at the rear of the trailer on it's plate. Works extremely well.
I have found this camera very clear and it has never washed out as you mentioned. It has been through car washes and rain storms and still works flawlessly.
Try it. You might just be pleased with it. I am. It hasn't accumulated any dirt really. I'll just wipe my finger across it on occasion if it's rained.
The whole setup took me about an hour to do. Takes about 30 seconds to swap the power plugs and move camera to trailer.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
