- kgarrett9999Explorer
FSAD wrote:
kgarrett9999 wrote:
Remote Switch
Looks like this might be what you're looking for.
I'd be interested in your final solution so be sure to post back here whatever you end up with.
it would appear I read wrong, seems you push a button and it will run for the prescribed time (10-60 sec).
I found another one on their site, doesn't have a delay:
Other one
I emailed them asking about both, will keep you posted.
thanks all!
mikey
edit: course now that I think about it one MIGHT want a run delay, that way your not pushing the transmitter and having to hold it while the motor runs, might wear out the transmitter battery quicker. hmmmm... lets see what they say
I didn't notice the delay thing till after I posted it. The other one that you posted should do the job. - westendExplorerThe Alta remote system linked to by 96Bounder is exactly what you need. It has the wireless function, momentary switching, and can handle the amp load of the jack.
- FSADExplorerI was looking at my supply wires for the jack, they cant be TOO heavy duty, they are about 14 gage looking. and that's what came with it! it is a pretty large gear reduction in there (noticing the last time I greased the gears), so perhaps amp draw isn't much.
I'll email Buyers products (the jack mfg) and see....
that Alta control looks really overkill... - DougEExplorerThe HF winch control is just control voltage. You would need to add a pair of contactors to handle the load of the jack motor.
- 96Bounder30EExplorer II
- FSADExplorer
DougE wrote:
If you're handy with electrical I bet you could adapt this remote winch control from Harbor Freight.
Looks like it might work, looks huge too!
Shouldn't be too hard to wire up, wonder what the amp rating is? Probably high, since its for winches.
hmmmm - DSDP_DonExplorer"FSAD"......I like your idea. You may have a marketable item. My kids both have trailer with an electric tongue jack. I could picture and assembly with both a manual and remote switch in case of failure.
"DougE".....I think I'll stop by Harbor Freight and grab one. It should be easy to plug into the kid's jacks. - DougEExplorerIf you're handy with electrical I bet you could adapt this remote winch control from Harbor Freight.
- FSADExplorer
hawkeye-08 wrote:
FSAD wrote:
Husky said cant order parts. Waiting on the RFControls guys
That RF control had 5A limit. My electric jack has 30A fuse, not sure what it draws when running steady.
hmmm, I see..... there are a few more on their main page
list of remotes - hawkeye-08Explorer III
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 19, 2025
