Gjac's avatar
Gjac
Explorer III
Aug 29, 2018
Remote switches not working on Genset
Finally fixed my Kohlar 5CKM21 genset and works fine from start switch on genset itself. Neither the dash remote switch or the remote start switch above the stove will start the generator. Both will work to stop the generator but no start on either. Because both switches don't work I figured the problem was not the switch itself and thought I would check the connections at the genset itself for corrosion or loose wiring first. I can see where the wires from the genset start/stop switch plug into the control board then saw 4 wires coming into that plug from another harness up front. Removed plug and re plugged several times but still no start. Any other ideas?
