Gjac
Sep 01, 2018Explorer III
MySuncoastRV wrote:Cannot see a 10 amp fuse inside genset cover. Saw and checked 2 5 amp fuses and a 15 amp fuse on the face plate and all were good. reset two 30 amp circuit breakers.
The stop portion of the switches uses a grounding circuit. The start switch uses a 12v input. The onboard switch is independent from the remote switches and that's why it functions as normal. Look for a 10amp fuse on the remote switch circuit within the generator cover. More than likely tucked within the wiring loom near the front panel. Hope this helps. Keep us posted.
38,782 PostsLatest Activity: Sep 10, 2026
