Gjac
Sep 01, 2018Explorer III
rgatijnet1 wrote:The genset starter switch hooks up directly to the control board along with the remote starter wires. They are all in the same plug that plugs into board.
About the only thing left is the path of 12 volts from the switch to the generator starter. Since the switch on the starter works, then about the only thing left is an open somewhere in the wire from the other switches to the starter. I still think that the two switches are in parallel so there may only be one wire going from them to the generator starter. I see no reason why it would not hook up to the same place as your generator starter switch rather than going to an electronic board. In other words, I am thinking all three switches should be wired in parallel.
38,782 PostsLatest Activity: Sep 10, 2026
