rgatijnet1
Aug 31, 2018Explorer III
One of the problems with tracing continuity and voltage is that if even if one strand of a 100 strand wire is still connected, the voltage will read correct and so with the continuity. In spite of these good readings the single strand of wire will not have the current carrying capacity(amperage) to energize the starter. I am guessing that somewhere between the 12 volt source and the switches, the wire is frayed(maybe partially rodent eaten) to the point where it cannot supply enough amps to energize the starter.
You may want to try bringing another 12 volt source wire to the switch and see if that works.
I think that by trying the jumper cable ground connection earlier, we eliminated a frayed ground wire.
38,782 PostsLatest Activity: Sep 10, 2026
