gafidler's avatar
gafidler
wiring CRV for towing
can the brake wire on a 5 pin plug be use as the charge wire to the battery ?
1 Reply
  • Yes you can use the "Trailer brake wire" for a charge line.I would use
    a #12 AWG wire and fuse it at 20 amps or use an Auto-Reset breaker.
    Make sure you have 12Volt connected to that pin from the MH when IGN is ON.
    Siggy
