- hilldudeExplorerThe separate lights are easy, look at instructions for installing Blue Ox base plate. You will find instructions for installing bulbs in tail lights, I used roadmaster lights. Etrailer has a video on youtube installing lights on Focus.
- B_s_BunchExplorerCheck out Tow Daddy. easy install and works so far no complaints. Mag lites can sometimes be a pain. As in having metal to attach to and where to store them when you are camped. Tow Daddy.com I believe. Larry
- rmmpeExplorerTim,
Let's do this in our usual manner.
Look at your e-mail. - HealeymanExplorer
rmmpe wrote:
I sent you a schematic.
Hey Bobby,
I got the .jpg, but it was pretty much unreadable both small and worse when blown up.
Can you do anything else with it?
Tim - rmmpeExplorerTimmy, me Boyo,
I have a 2013 5-speed Focus and installed a completely separate set of LED lights to avoid messing with the OEM circuits. I sent you a schematic.
Bob - BumpyroadExplorer
D.E.Bishop wrote:
The easiest is magnetic lights but if your friend is going with diodes and is going to have supplemental braking, a stoplight relay may be necessary. With separate bulbs and sockets it is just like the magnetic lights.
x2, separate bulbs won't "mess with" any computers in the toad.
bumpy - D_E_BishopExplorerThe easiest is magnetic lights but if your friend is going with diodes and is going to have supplemental braking, a stoplight relay may be necessary. With separate bulbs and sockets it is just like the magnetic lights.
