jim1632
Nov 26, 2018Explorer
I used the square hole to insert a length of rope with a large washer attached so I do not lose the plug during dumping. Be sure not to use a long screw to attach the free end to the outside of the tube or you risk making holes in the hose as it is inserted or removed. Also I removed enough of the screws from the tubing cover on my RV to avoid tears from those along the length os the storage area.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
