DutchmenSport
Jun 23, 2014Explorer
Our free standing table is held down with 2 wood screws through the foot of the table. And yes, the floors are wood, same as the main part of your coach area.
You should have no problems removing the table (assuming it's a table and 4 chairs). Even a dinette is just screwed down with wood screws and easily removed.
However, the thing you need to consider before you dismantle... can you dismantle enough to get it out the door? Often times, items are put inside the camper before the walls are actually put in place.
I see no problems with your proposal. And if you end up messing up the table, you can easily put a different one in there when you get ready to sell it. No problem. (provided it will fit through the door).
