machunt's avatar
machunt
would you
On my way to another campground i picked up a nail in my brand new duravis r250 tire on the 5ver, had a company come out and they put a plug in the hole which was not in the sidewall but between the tread and they thought it was good to go. my question is should i go ahead and travel or use this tire as my spare?
  • Fixed flats for extra money in school. Never had a plug leak but did have some patches leak.
  • Patching is the normal method of repair. But I have never had a plug fail either.
    A couple years ago I had a 1/4" metal rod about 6" long puncture one of my almost new tires thru the tread. They had to put a plug in to fill the hole. Still on the ground and still holding air fine after several thousand miles.
  • I would stop at next chance and have it patched and plugged from the inside. In the meanwhile keep a close eye on your TPMS.
  • having been a tire buster back in the day, a patch was always considered a much better solution than plugging it.
    unless some new technology has come around, i would only consider a plug to be a temporary fix until i could get the tire into a shop to have it patched on the inside.
  • I carry a kit and plug my own tires when on the road. I do dismount and patch from the inside when I get home.
  • In my experience, plugging a tire in the tread area is ok, but never in the sidewall.
  • if your spare is as good or better than that tire in terms of age and tread then sure, make the switch. but a properly repaired tire should provide you with the same service as an tire that has never been repaired.
Looking for advice before your next adventure? Look no further.25,114 PostsLatest Activity: Feb 24, 2025
Related Content
