- down_homeExplorer IIWe have the large clear suction cups. We use them for heavy wreaths at home, and on the coach, at Christmas. have to watch for the wreath banging against the glass at its bottom. Probably bought them at Wally World or Hobby Lobby.
- ependydadExplorerI'd be more concerned about damage from the wreath moving. I'd be more apt to hang it beside of the door rather than directly on it.
Sounds like I may be worrying for nothing with Hunter11 saying he/she has not had issues. - Hunter11Explorer IIMy wife uses a Command Hook to attach one to ours each Christmas. It works well and no damage after she pulls it off.
- Dutch_12078Explorer III
kelly94942 wrote:
Too Young to Retire wrote:
They make a wreath hook that just hooks over the top of the door. It should also work on an RV. Google is your friend.
found this on Amazon
I do have one of those, but can't imagine it would work the way it works with a regular door because of the configuration of the RV door.
Sounds like Command Hooks are the way to go! :)
We have one similar to the one on Amazon. A few minutes with pliers modified the hook to fit the lip at the top of our coach door. - kelly94942Explorer
Sounds like Command Hooks are the way to go! :) - wa8yxmExplorer IIICommand hooks are good and usually do not hurt the finish, If you have glass in the door hook it there.. I forget how I did mine, but I may have modified an over the door hook so it would work, easy to do.
- Too_Young_to_ReExplorerThey make a wreath hook that just hooks over the top of the door. It should also work on an RV. Google is your friend.
found this on Amazon - Okie_in_WyomingExplorerI think a Command hook would work very well.
Just remember to remove the wreath before you travel, :)
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
