mobeewan
May 10, 2020Explorer
I'll second on the pollen.
If you don't have a good water fill connection enclosed behind a hatch or door, everything that gets washed down the side of the trailer when it rains can get in the vent tube or the water fill port if it doesn't have a cap.
I had my trailer in to a dealer to get the roof Corners resealed because the caulking was looking bad. While I had it there I also paid for them to wash and wax it. About a week after I got it back I found liquid wax that was sprayed on it in the fresh water fill hose. There was pink wax residue from the spray on wax that ran down the side of the trailer and gotten into the fresh water fill hose.
The water fill port looked similar to the shorepower mouse hole with the same type of flap that snapped closed over the opening. I wasn't too happy about that one. I had to remove the fill hose between the outside hatch and the tank and scrub it out with a bottle brush and Dawn then reinstall the hose. I'm not sure if anything got into the tank but I flushed it a couple of times just in case.
Within a month I replaced the cheap water fill port with a lockable hatch type after I found sediment that looked like dirt in the hose again after I had cleaned the wax out. I figured it was dust and dirt that rainwater had carried down the side of the trailer and it had weeped into the cheap water fill port.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
