ike66's avatar
ike66
yellowing plastic trim
The plastic trim around the door window, awning motors, and stove vent cover have yellowed over time. Is there a way to bleach these back to white or do I just paint them.
  • Plastic have a UV inhibitor that gets "burned away" over time. Painting is the best cure as even sanding the yellow off doesn't help the fact that the plastic is compromised.
  • I use Clorox Kitchen Cleanup with bleach. Spray it on, go have a cold one ... or 2, rinse. Also works well on the AC outlet covers and grab handle next to the door.
  • I used Krylon Fusion about 5 or 6 years ago to paint the trim around my door windows. I am amazed how well it has held up even with all the rain we get around here. It still looks better than new.
    Amazing stuff.
  • A friend of ours accidently discovered that Windex makes it white again. Who knew?
  • Careful use of lacquer thinner will bring the white back. But after your going to have to further protect the plastic. Spray paint would be a good start.
  • Rumor has it a Magic Eraser will bring it back. Can't confirm it though.
  • I painted mine with a bright white spray paint that is rated for plastics. I bought it at Home Depot (it seems like a lot of new paints are good for plastics). It is a bit of work taping and adding newspapers around the areas that are to be painted but they look brand new again. I did this 2 years ago and they still look great.
