Songbirds's avatar
Songbirds
You might be an RV if?
Here is some HUMOR we can all play along, by adding to the phrase.
Most of us may know the funny comedian Jeff Foxworthy, and his famous lines of "you might be a Red Neck if?"
This one is for fun and every RV'er can play along by adding a line. So finish the following line,
If you have a Towed following you down the road.
So before you Answer add the phrase "You might be an RV if" and then your ANSWER, to your post below.
  • You might be an RV'er if you drive your regular pickup 25' past the gas pump to fill up then realize you aren't in the RV. (My RV filler cap is in the rear)
  • You might be an RVer if you freak out about exceeding payload by the weight of your Big Mac for lunch.
    Mike
  • You might be an RVer if you spend hours each day on this forum. :E
    Barney
  • Moved from Around the Campfire as it is strictly for non-rving topics.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 12, 2026
