suprz
Jun 17, 2019Explorer
Which shocks IF...
You can't afford bilstein? I'm wondering if waiting to afford bilstein shocks versus getting shocks now is worth it, or even safe and which shock you would recommend
Bordercollie wrote:
What would be the best way to improve harsh ride from rear duals on cupped concrete highways. ( Change rear springs, add airbags or ??) We get out and walk around at rest stops. Tioga 26Q 80 psi in rear tires, 75 in fronts.
DrewE wrote:I believe the most influential factor is that our E350 is 23'-8" long with a 158" wheelbase resulting in a significant rear overhang. Then adding that our fresh water tank is against the rear wall (and we always carry a full tank), the teeter-totter effect lifts & lightens the front axle.pnichols wrote:Raising the rear does not transfer any significant amount of weight to the front, any more than parking on a slight hill does. Probably a pet walking from the rear to the front of the motor home causes about as much weight transfer.
Ron, of course if your heavy duty front shocks also mean that they're stiffer shocks - then your front ride could be rougher than necessary for two reasons -> under loaded front coil springs plus shocks that don't compress/extend as easily.
Do you have rear air bags that you can adjust to permanently raise the rear and hence transfer more weight unto the front?
I guess if you raise the rear by several feet things would start to be a little different....
pnichols wrote:
Ron, of course if your heavy duty front shocks also mean that they're stiffer shocks - then your front ride could be rougher than necessary for two reasons -> underloaded front coil springs plus shocks that don't compress/extend as easily.
FunTwoDrv wrote:Hi Gary,
Ron,
That cupping on your right tire looked very much like the tires on our C. Unfortunately this happened after we put new shocks on. The tire mfg said it was due to us not rotating the tires. However, Michelin dealer claimed it was due to an out-of-balance issue caused by a belt failure... who knows! I put a new set of Michelins on and are watching them closely so as to not revisit this same issue down the road.
Gary
FunTwoDrv wrote:
Although we went with Bilstien shocks, my thinking is to go with the best shock you can afford. Our Chevy 4500 chassis had two completely worn out shocks at 17K miles... one front & one rear!Lumpty wrote:
I had Bilsteins on the front of my E450, and found the digressive valving too floaty as I'm lightly loaded with a no-slide 24' house. The front tires were cupping badly. Switched to a pair of Monroe Magnum RV shocks, which were all of something like $25/each using an Advance Auto coupon, and they resulted in a much more controlled ride, and also the tires are wearing evenly as the twin I-beam front end isn't going up and down all the time with it's inherent toe change.
Lumpy, could you elaborate on the "cupping" you experienced? Our current tires are starting to show cupping in the center of the tread. Scheduled Friday to replace all six with Michelin.
Gary
