dougrainer
Aug 08, 2016Nomad
Remove the drain tube plastic end and plug the hose. DRIVE and see if the problem goes away. As another stated, IF the flame goes out, you will have a Check Light. Are you POSITVE the inside doors are shut TIGHT? Is this the same problem you had with the Atwood Refer? Doug
