EldIr
Oct 15, 2013Explorer
$.80 solar panels
A while back, maybe months, maybe last year, someone posted a link to solar panels for 80 cents per watt. I've tried searching but can't find it. I've also looked around eBay and Amazon and can't fi...
BFL13 wrote:
There is a saving in solar where the controller only has to step down to 24v instead of 12v to run things. So a 24v inverter on a 24v battery bank supplying 120v has that advantage. Going to 48v even greater. You lose that when you choose 12v systems that need the controller to step down to 12v.
It would be interesting to compare the savings using 12v direct rather than bricks taking in 120v from inverter with the solar savings from only having to step it down to 24 or 48v.
The Rv is tied to 12v by the fridge and furnace control boards needing 12v even though they run on propane. Otherwise, you could do everything with 120v.
A cabin can have 120v for res fridge and heaters, so no more 12v.
