A while back, maybe months, maybe last year, someone posted a link to solar panels for 80 cents per watt. I've tried searching but can't find it. I've also looked around eBay and Amazon and can't fi...
Newer pure sine inverters up to 1000w output use around .5 amps or less when not powering a load. Nearly all are better than 94% efficient.
You'll have to make the decision whether having all 12V appliances is better than a mix of 12V and 120V items but I'm guessing that you are going to have some of each. That means an inverter is going to be in use, anyway. FWIW, I think the difference in standby load between a Samlex 600W and a Xantrex 1000W is less than 250 MA, maybe less.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
