time2roll
Jul 02, 2016Nomad
Those pictured settings have no bearing on the normal battery charge function.
The settings are fine if you do use load control although low voltage disconnect at 12.0 would be easier on the battery if you do use the function and the load is not critical.
Just use duct tape to hold the sensor against the battery case.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
