Dr__Feelgood's avatar
Dr__Feelgood
? Charging Electric Bike Battery
I'm short on Electrical know how and just got E bike with Samsung 36 volt ,14,25 Ah battery. Came with 110V AC charger. Normally takes 4-5 hrs to recharge per their info. When off grid I want to charge from inverter. Would a portable 400 Watt inverter plugged into Cig Lighter in truck be OK? I hope eventually to get solar with adequate inverter for TC.Does this affect charging time?
Any good discussions on line?
Thanks
  • ^ Good point.
    If you run the bike battery down to 50 percent charge, it will deplete your truck battery by approx 25 Ah to bring the bike battery back up to full.
  • Well, you'll be pushing the limits of the cigarette lighter plug, and running your truck's battery down.
    As your truck battery voltage drops, the Amps will increase to maintain power on the inverter side. It's a vicious cycle; more Amps makes the battery drain quicker, which makes the inverter draw more Amps, which makes the battery drain even quicker, and so on.
    I'm personally not real big on inverters unless you've got a big battery bank and solar to recharge it.
  • The specs for that battery say max charging amps is 5 amp. A 400 watt inverter at 80 percent efficiency will give you about 9 amps @ 36v. So you will be OK. Some charger don't play nice with a MSW inverter, so get a pure sine wave inverter.
  • Look on the charger for specs. Need to know the amps.
Having RV issues? Connect with others who have been in your shoes.24,285 PostsLatest Activity: Jul 22, 2025
