time2roll
Aug 19, 2021Nomad
kabbro wrote:Yes.
Oops, thought of another question: if when I take the battery into a battery shop and they test it and if they say it’s “good”, then presumably the problem would be a failing converter?
If you have a voltmeter you could find out right now by looking for 13.6 volts on the battery or to the cable if you disconnect a battery cable.
Is the battery warm and bubbling?
If you have a 10+ amp portable battery charger you could bring it along to use in place of the converter depending on the time you have to get this sorted out.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
