MEXICOWANDERER
Apr 22, 2016Explorer
Good Lord!
Do you lash a ten year old because he cannot run when burdened with a sack of portland cement? "Hey Dewey! Shake the jar and see if they fight"
102 volts. Check your battery connections because it is something you can do for free. You ain't gonna like hearing the truth. Mix up a big martini and relax.
MSW uses stepped waveform. It has a peak but it is somewhere in the RMS vicinity, County? State? Hemisphere?
Your inverter is perverted. It hates you.
Load it with a 1,500 watt heater. Wear a mask and gloves. Put the local recycle center on "auto-dial". Right after "Fire Department"
Seriously. Treat the device as being damaged. Protect yourself when testing. This is no joke. If your meter is any good, the inverter is history.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
