Kayteg1
Apr 22, 2016Explorer II
MEXICOWANDERER wrote:
Load it with a 1,500 watt heater. Wear a mask and gloves. Put the local recycle center on "auto-dial". Right after "Fire Department"
That's a miss. I did what you said and the heater works just fine, although operating from single battery low voltage warning come on.
In strange way the 102V no load come up to 110V under the load.
The inverter operates the panel as well, just will not start up AC.
So with all the suggested tests, I can see that the 9V inverter sends between ground and neutral is what was turning the switch light on.
Anybody having different idea, let me know?
EDIT Drew typed at the same time I was typing above and sounds like we come to the same conclusions. He beat me to it. ;)
Thanks guys.
This is heater wiring. It might not be clear, but Camco is using ground for control light.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
