12thgenusa
Apr 22, 2016Explorer
Kayteg1 wrote:
One more idea. Assuming somewhere in the future I will get big solar panels and big battery bank and will try to run AC with this inverter.
I have generator with automatic transfer switch that suppose to be very fast.
What are the chances that I will start AC on generator power, having inverter on as well and at the moment I kill generator, the 1750W inverter should keep the AC running? Am I missing something?
Chances are zero.
Yes, you are missing something. That inverter will never run the air conditioner and "quick draw" start won't help it. Most ACs have a time delay that once the compressor stops it won't attempt a restart for several minutes. This is to allow compressor head pressures to drop somewhat. Don't forget, the compressor cycles on and off when the AC is on. My 2K PSW inverter won't start the AC.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
