Kayteg1's avatar
Kayteg1
Explorer II
Apr 22, 2016
? for electric/electronic experts.
I have camper with build in converter that also has 120V breakers on it.
Recently I added electric element for water heater and hard wire it to AC breaker. The switch on the wall has small light that comes on when heater is on.
I also added 1750W inverter, that is directly hook up to the battery and I just plug coffee maker or microwave to it when I need it.
Today just for the sake of it, I tried to to run AC off my 1750 inverter. I pulled main camper cable and plug it into inverter with converter breaker off. AC did not start, hesitating for few seconds before inverter went to overload, but what I noticed, the control light on heater element was on.
I flipped all 120V breakers off and the light was still on, regardless if the switch was on or off.
So somehow the inverter power with shore cord on it back-feed to the switch.
I know those control lights can run on big margin of voltage and I think that with my mechanical education I am pretty good in electrics, but that keeps me scratching my head with no idea.
So one more time - 120V on shore cable coming from inverter, with all 120 breakers off feeds somehow via ground and neutral wires to keep the switch control light on.
What da heck?
  • Sounds like a floating neutral. You might measure 60 volts between neutral and ground, and 60 volts between hot and ground.
  • Switch light is wired between ground and the element hot wire.
    No 12v used in this set.
    I am thinking the inverter send some kind of ghost voltage via neutral wire and that backfeeds to the light via the heater.
    Not real life problem as I will not use that kind of configuration, but having light coming on when switch is off sure makes your hair standing.
  • How is the switch wired? as an example mine runs on 12 volts (the switch) and triggers a relay to apply power. 2 You CAN NOT run your A/C with such a small inverter and if you could you would need a LARGE battery bank to maintain it.
    Good Luck!
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
