MrWizard's avatar
MrWizard
Moderator
May 24, 2019
@#$%^& onan starter
Marquis 5000, mpdel BGMFxxxxxx
starter spins and rattles does not engage, it worked at lunch
anyway i need the correct part number so i can pick one out of the myriad of online sales offers
will probably order from Amazon so i can get it soon as possible
and install
this just had to happen on a Friday of a holiday weekend
AWE $HxT .. dang it
downloaded the PDF of service manual, NO part number for stater
currently looking online for parts list and part number
  • sorry slow follow up
    starter is in, and generator is running fine
    still need to take a couple pictures of that splash guard/flange
    to help clarify what i posted
  • hopefully you get correct part with that part number. that is old, superceded number. current Onan part number is 191-2416.
    Good luck with that repair. The older Onan Marquis series generators were great units, imho.
  • did some exploring and dissamebly today
    the back side 'splash plate' ?
    is just a flange that can be removed to give access to the starter and fuel pump
    3 screws hold it to the bottom of the RV
    4 bolts (2) on each end, hold it to 'pan' holding the Onan
    it was not easy getting a socket or wrench on the inside to hold the bolt head
    while i undid the 1/2 nut on the outside
    but the flange out of the way access to the starter is much better
    will have it running again by Sunday afternoon
    sorry NO pictures, very dirty hands and no one to be my photographer
  • found it on amazon $56 be here on Tuesday
    nothing is going to get here any faster, some are cheaper both amazon and ebay
    but won't get here until the the 31st or later
    edit;
    getting it delivered to an amazon locker nearby, be here on Sunday the 26th
