Sam_Spade
Jul 04, 2016Explorer
pnichols wrote:
that required a float voltage around 13.6 volts so that I could use our RV's stock converter with them without ruining them ("drying them out").
It's comments like this that confuse people.
First, unless you do something REALLY stupid, you can not "dry out" an AGM battery. The water that electrolyzes re-combines back into water.
Second, having the charging voltage a couple of tenths lower than optimal will NOT cause any damage to an AGM battery; nada, none.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
