MEXICOWANDERER
Jul 15, 2016Explorer
Excessive plate erosion is what manufacturers strive to reduce. Acid being acid becomes more robust then regresses to being purely vicious as electrolyte exceeds 40c.
Yes or no? is there a temperature compensated 120 vac converter out there that meets Lifeline or Rolls & Surrette, temperature compensated specs for both bulk and float maintenance? "Dry them out?" Who at Lifeline verbatim declared 13.6 volts WILL DRY OUT A LIFELINE BATTERY? Please furnish a tech rep name? My MEE FINDING of not losing one gram of total unit weight over a period of 18-months makes a mockery of such a statement. Subtle voltage increase over Lifeline's recommended 13.2 - 13.3 volts @ 25c lineraly increase positive plate erosion. Now couple that bit of data with the fact that Lifeline batteries regularly last 5+ years IN UNDER-HOOD AUTOMOTIVE SERVICE. And I freakin' guarantee automotive regulator set points are not 13.2 volts, and I freakin' guarantee under-hood temperatures are not twenty-five degrees Celsius.
Many of you should be asking questions not making statements that defy logic or engineering expertise.
